Help with my new build?
I have been thinking of purchasing/building a PC for almost a year now, and it's almost time. I have done countless hours of research and asked several questions on the forum and I think I'm almost ready. I'm 14, turning 15 in December, and would use the PC for gaming, school, web, and movies. My plan since last December has been to purchase all the parts for the PC on Black Friday, so It's getting closer and it would help me out a ton if you would look at the build. Feel free to make any suggestions!
Approx. Purchase date: Black Friday
Budget Range: >$1400 (with mouse, keyboard and monitor)
System Usage: Gaming, (BF3, Dishonored, Assassin's Creed III, Far Cry 3, Chivalry: Medieval Warfare, Sleeping Dogs, etc.) School, web, video/photo editing
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preffered websites for parts: microcenter.com, newegg.com
Parts:
GPU: http://bit.ly/N5FE5f
CPU: http://bit.ly/Pq90qR
MoBo: http://bit.ly/VrPY5J
HDD: http://bit.ly/RZpNCB
SDD: http://bit.ly/RYQwyI
PSU (Need help on this one): http://bitly.com/RLwCIr
RAM: http://bit.ly/WME4bA
Case: http://bit.ly/MLd4iH
DVD Drive: http://bit.ly/RLxOvf
OS: http://bit.ly/TdccpW
Price (Case Only): about $1055
How is everything? Any suggestions? How can I tell if everything's compatible? Can you give me recommendations on mice, keyboards, and monitors? Also how's the PSU?
2 answers Last reply
More about help build
  1. That all looks good with the exception of your PSU, RAM, and SSD. Get these instead:
    PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
    SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147163
    RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231546
    And then add a Hyper 212 Evo and you're set.
  2. Nice build and just that much better with the addition of G-units parts.
    If your plan on doing some extreme overclocking then i would recommend a Noctua dh-14 cooler over the 212EVO because it does cool a bit better, but you pay for it. The EVO is great for the price.
    To check if the stuff is compatible (which it is) you could always check out:
    http://pcpartpicker.com
    For a mouse i would recommend a Razer Deathadder and a Logitech G110 for the keyboard.
    Monitors are personal preference but i would recommend most from Asus. Dell also has nice screens but there are so many out there its tough to narrow it down.
    Good luck with the build it looks solid my friend.
New Build New Build Systems Product
