so, guys i need some help to decide.
a few months ago i was given the advice to go for Gigabyte GA-Z77X-UD3H.
the only thing which is causing me a dilemma is the SLI: opting for a Windforce, the SLI support must be a Quad one. yet the Gigabyte GA-Z77X-UD3H supports only 2 way. on the Sabertooth supports a quad interface.
which one should i go for according to you? what do you think of Gigabyte GA-Z77X-UD5H as an alternative?
btw, i would appriciate if someone could suggest me a good UPS. the following link illustrates the possible build:
http://pcpartpicker.com/uk/p/lqwb
