I bought a new set of headphones and I have always put my headphones in the rear on my PC. The headphones are more expensive than my last ones, which were really cheap. I noticed that the audio is pretty clear but it seemed to be lower quality for some reason.
I have an integrated sound card, Realtek HD Audio. I thought I'd give it a try and put the headphones in the front, and the difference was pretty huge. While listening to a song, it seemed to me that the sound was a bit more muffled but it had more powerful bass. The front jack is listed as Realtek HD Audio 2nd output and the rear is listed as Speakers.
I also checked the default format from playback devices -> properties -> advanced. When the headphones are in the rear, the default format is 24 bit, 48 KHz (Studio quality) but when I put them in the front, all the choices had "2 channels" added to them and the default choice was 2 channels, 16 bit, 48 KHz (DVD quality).
Am I supposed to use the front jack for headphones and why such a difference? I thought the rule of thumb is always to put external devices straight to motherboard if possible.
I also posted this in Windows 7 forum but I deleted it since I thought this would be a better place to ask.
