Help with no sound on Dell desktop PC
  • Sound Cards
  • Desktops
  • Dell
  • Components
Last response: in Components
March 10, 2013 4:33:08 PM
no sound coming from my computer
More about : sound dell desktop
March 10, 2013 4:54:11 PM
Do you have speakers connected and do they work?
m
l
March 10, 2013 5:19:29 PM
speakers work brand new in disconnected them
m
l
March 10, 2013 5:21:44 PM
i disconnectd them
m
l
March 10, 2013 7:16:31 PM
By disconnecting the speakers you cannot get sound , to get sound you need to connect the speakers.
m
l
March 10, 2013 7:16:51 PM
i have new speakers and they are not producing any sound, what do i need to do in order to acheive sound
m
l
March 10, 2013 7:18:20 PM
ok, they are connected now...now what
m
l
March 10, 2013 7:21:36 PM
You have to go into the control panel and under sound and hardware make sure that the sound card is selected to be enabled and that the speakers are selected as the hardware to be used for sound. If your motherboard has a built in sound chip then in the bios you have to make sure that it's enabled and that you have loaded the sound chips drivers off the motherboard driver cd.
m
l
