List of what I'm at as of now, just want to know if there's anything better for the same price or cheaper. If the increase is minimal for the cost don't bother. And this is a overclocking build
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
http://us.ncix.com/products/?sku=64385&vpn=RR-212E-20PK-R2&manufacture=COOLERMASTER
MSI Z77A-G45 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130645
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
Samsung 830 Series 128GB 2.5" Solid State Disk
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147134&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
http://us.ncix.com/products/?sku=65701&vpn=ST1000DM003&manufacture=Seagate&promoid=1296
HIS Radeon HD 7870 2GB Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
NZXT Phantom PHAN-001BK Black Steel / Plastic Enthusiast ATX Full Tower Computer Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068
Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
LG GH24NS90 DVD/CD Writer
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136247&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
Asus VE248H 24.0" Monitor
http://us.ncix.com/products/?sku=56381&vpn=VE248H&manufacture=ASUS&promoid=1389
Microsoft Windows 7 Home Premium SP1 (64-bit)
http://www.amazon.com/dp/B004Q0PT3I/?tag=pcpapi-20
Approximate Purchase Date: By Black Friday
Budget Range:
System Usage from Most to Least Important: Gaming,surfing the internet, movies
Are you buying a monitor: Yes
Parts to Upgrade: Starting completely new
Do you need to buy OS: Yes
Preferred Website(s) for Parts: newegg
Parts Preferences: None, whatever works best
Overclocking: Yes
SLI or Crossfire: no
Your Monitor Resolution: Not sure yet
Additional Comments: Would like it to look cool depending how much extra that cost and don't want it super loud
And Most Importantly, Why Are You Upgrading: old computer broke it was crap anyways
Budget Range:
Overclocking: Yes
