Is there any way I can reduce my Pc sleep power consumption?
If I put a socket power meter on the pc while it is in sleep to says it's drawing 27 watts. It is the same for both my pc's. It is around 90 watts while in use.
Is this right? "Short of buying a more expensive power meter to test properly"
If it is 27 watts draw then is there any way to get it down but still retain all the functionality of sleep mode like wake on lan, remote power on, wake to record ect..
Currently the standby cost of the Htpc is about €50 a year.
Both pc's are running windows 7 64bit.
Bios is set to S3 power state I think. But I have tried them all. Sleep always draws up to 30 watts at the socket.
