Nvidia Geforce 660ti Power Question
Hello,
I just put the Geforce 660ti into my computer and it came with 2-6 pin connectors. However, I only have enough connections from my power supply to connect one of them in. Each 6-pin connector has two power cables (so there's four in all) branching off of them, so I have two of the power connectors plugged in total.
Will this be enough for my GPU to run fine?
My PSU is 700 watts.
1 answer Last reply
More about nvidia geforce 660ti power question
  1. I'm a little confused what this statement means:
    But as long as you have the card plugged in, you should be OK as long as your PSU isn't complete garbage... the 660ti is not a very power hungry card.
    If you want to know for sure, you'll have to tell us the make and model of your power supply - just knowing the wattage isn't enough information to know for certain if you'll be OK or not.
  2. coolmaster 700 watt psu.
Graphics Cards Power Geforce Graphics
