Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
I inserted sandisk 128mb to laptop hp nc6000 - windows
xp. it detected new hardware, but can't find out drive on
window explorer.
When i plugged of the SD card, the taskbar still shown
new hardware found and request a driver. In device
manager, it shown "base system device" that still looking
for the driver.
Any suggestion to fix this? what kind of hardware
is "base system device" and where i can find out the
driver?
I'm sorry but your question doesn't make any sense...... are you using a
card reader that is built into the HP NC6000? Or a separate card reader,
manufactured by some other company connected to a USB port on the notebook?
If the card reader is part of the HP notebook, then the driver for that
hardware should already be installed... UNLESS you have changed or upgraded
the operating system, in which case drivers should be available at the HP
website.
If you are using an external card reader, connected to the USB port then
Windows should have installed the drivers automatically on detection on the
new hardware.
Cari
MS-MVP Windows Technologies - Printing/Imaging/Hardware
www.coribright.com "Tono" <anonymous@discussions.microsoft.com> wrote in message
news:b60701c4376a$5477e0a0$a101280a@phx.gbl...
> window explorer.
> for the driver.
> driver?
> many thanks friends,
Cari, thanks for your help..
the sandisk SD card was inserted to the slot that built
into HP NC6000.
is "base system device" means this slot?
tono
>-----Original Message-----
are you using a
driver for that
changed or upgraded
available at the HP
>website.
the USB port then
on detection on the
>new hardware.
>Cari
>www.coribright.com
message
on
>> window explorer.
looking
>> for the driver.
>> driver?
>> many thanks friends, >
Probably the O2Micro drivers.
Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
www.coribright.com
news:b9f701c437b9$29240380$a101280a@phx.gbl...
> into HP NC6000.
> tono
> are you using a
> driver for that
> changed or upgraded
> available at the HP
> >website.
> the USB port then
> on detection on the
> >new hardware.
> >Cari
> >www.coribright.com
> message
> on
> >> window explorer.
> looking
> >> for the driver.
> >> driver?
> >> many thanks friends, > >
