New system build (3D work and casual gaming)
Hi everyone !
Need some advise on my new built :
Processor : INTEL CORE i7 3770K 3.50Ghz (8MB CACHE)
MotherBoard : Gigabyte GA-Z77X-UD5H | Asus sabertooth Z77
HDD : 1TB caviar Black + 1T caviar green .
RAM : CORSAIR VENGEANCE DDR3 16 GB setup 4 x 4
GFX Card : Gigabyte GTX 670 ddr5 2 GB .
PC Case : Cooler Master "Storm Enforce" .
LED : Samsung syncmaster Samsung S24B300H 24" .
Cpu Cooler : CM HYPER 212 EVO
PowerSupply :
Cooler Master silent PRO MII 850w | Cooler Master silent pro Gold 800w | CORSAIR 850W HX MODULAR
SSD : Intel SSD 320 series 120 GB
Trying to keep the setup under $1800 while still being as effective . My usage will include 3d application . gpu rendering and casual gaming . I will be moderately OCing my system but not too extreme for now .
I am inclined towards the Gigabyte motherboard . Also it might give better compatibility with GPU by the same manufacturer ?
I am also still not sure which psu to purchase . Unfortunately my region is flooded with CoolerMaster psu with some limited corsair and thermaltake units .
Thanks .
ps : created this thread b4 in the wrong section which was moved . Could never find the moved thread so creating a new one
3 answers Last reply
More about system build work casual gaming
  1. A different motherboard won't give "better compatibility" with a GPU.
    The Sabertooth is great, but you'd be better off witha cheaper motherboard.
    800-850w is too much. Gee 650w.
  2. My thoughts exactly . I didn't think there should be a compatibility issue . Initially I was looking for a a psu under 750W but as I am planning to go for 670 SLI down the road , I thought It would be better to purchase an 750w + .
  3. A good 650W is enough for dual cards, but get 750W.
    Upgrade the SSD to the likes of a Vertex 4 or Samsung 830. They outperform the Intel 330 and cost much less.
    Make sure to get low profile RAM, otherwise I foresee issues with them and the 212 EVO.
New Build Cooler Master Systems
