Custom Gaming PC Build Help...
jpmonster68
I am aiming to build a gaming PC for under $600 USD and i have a list of components in mind.
I know a little about computers, but i need feedback to know if all this is compatible, and if it can run ArmA II on Mid-High settings.
Here is the list- Thanks in advance :)----
http://www.amazon.com/Ultra-LSP-600-Watt-Power-Supply/dp/B007PFD6CC/ref=sr_1_fkmr0_1?s=electronics&ie=UTF8&qid=1346530495&sr=1-1-fkmr0&keywords=Ultra+LSP650+650-Watt+Power+Supply+-+ATX%2C+SATA-Ready%2C+SLI-Ready%2C+135mm+Fan
http://www.amazon.com/AMD-A8-3850-Quad-Core-Processor-AD3850WNGXBOX/dp/B0055ZCXVE/ref=cm_cr_dp_asin_lnk
http://www.amazon.com/gp/product/B0058G65I2/ref=s9_hps_bw_g147_ir010?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-9&pf_rd_r=0P77HDN2PXRKTJMXW6F8&pf_rd_t=101&pf_rd_p=1353700762&pf_rd_i=193870011
http://www.amazon.com/Cooler-Master-RC-431P-KWN2-Elite-Tower/dp/B005ZCTJ9Q/ref=pd_sim_sbs_pc_22
http://www.amazon.com/G-Skill-Sniper-Channel-Memory-F3-12800CL9D-8GBSR2/dp/B004V3TM8S/ref=sr_1_1?
s=pc&ie=UTF8&qid=1346555228&sr=1-1&keywords=GSkill+Sniper+1600mhz+RAM
http://www.amazon.com/Seagate-Barracuda-3-5-Inch-Internal-ST1000DM003/dp/B005T3GRNW/ref=sr_1_8?s=pc&ie=UTF8&qid=1346555473&sr=1-8
http://www.amazon.com/Windows-Premium-64bit-System-Builder/dp/B004Q0PT3I/ref=sr_1_1?s=software&ie=UTF8&qid=1346555728&sr=1-1&keywords=windows+7
http://www.amazon.com/Galaxy-GeForce-Express-Graphics-61TGS4HX2LTX/dp/B0083CA88G/ref=sr_1_22?s=pc&ie=UTF8&qid=1346559896&sr=1-22
P.S. i already have monitor, keyboard, and a mouse.
Honestly, that is a pretty lame build, and probably wont run Arma II at all. You're going to want something more like this:
Intel Pentium G630
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116406&Tpk=g630
$68
ASRock H61M-DGS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157315
$45
CORSAIR Builder Series CX500
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
$60
Rosewill REDBONE Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147159
$40
Crucial Ballistix sport 8GB (2 x 4GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148543
$35
Western Digital Caviar Blue
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
$70
SAMSUNG 22X DVD Burner...
Intel Pentium G630
$68
ASRock H61M-DGS
$45
$60
$40
$35
$70
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151244
$15
SAPPHIRE Radeon HD 6850 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
$150
Windows is $100
