[First Build] Need advice on my first build
GPU: Galaxy GeForce GTX 660 GC 2GB
Software: Microsoft Windows 8 64bit OEM
PSU: Silverstone Strider 500W ST50F-ES
Case: Sharkoon T28 Green Case USB 3.0
RAM: Corsair Vengeance CML8GX3M2A1600C9 8GB (2x4GB) DDR3
Opitical Drive: Samsung SH-224BB/BEBS SATA DVDRW Drive OEM
HDD: Seagate Barracuda 500GB ST500DM002
CPU: Intel Core i5 3470
Motherboard: Gigabyte GA-H77M-D3H Motherboard
Is this a good build and would it be able to run games on max settings.
tell me what to change to make it get 60+ fps.
site: http://www.pccasegear.com/index.php
thanks :D
2 answers Last reply
More about first build advice build
  1. Everything looks great actually.
    If you want more fps, swap the 660 for a 7870. Way better performance.
  2. since you didn't write a budget i could probably give you 2 build INTEL and AMD idk what you like and you can choose BOTH run BF3 SMOOTHLY so don't worry
    Build 1:- INTEL
    CPU: Intel Pentium G860 3.0GHz Dual-Core Processor ($68.99 @ Mac Mall)
    Motherboard: ASRock H61M-DGS Micro ATX LGA1155 Motherboard ($44.99 @ Amazon)
    Memory: Patriot Viper 3 8GB (2 x 4GB) DDR3-1600 Memory ($25.99 @ Newegg)
    Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Newegg)
    Video Card: MSI GeForce GTX 660 2GB Video Card ($209.98 @ NCIX US)
    Case: Rosewill REDBONE ATX Mid Tower Case ($34.99 @ Newegg)
    Power Supply: Antec 450W ATX12V Power Supply ($35.83 @ NCIX US)
    Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($15.99 @ Newegg)
    Total: $506.75
    Build 2:- INTEL (with core i3) why core i3? because in the pc above you WILL LAGG in BF3 Multiplayer in 64MAN MULTIPLAYER MATCHES
    CPU Intel Core i3-2100 3.1GHz Dual-Core Processor $109.99
    Motherboard ASRock B75M Micro ATX LGA1155 Motherboard $64.99
    Memory Patriot Viper 3 8GB (2 x 4GB) DDR3-1600 Memory $38.99
    Video Card MSI GeForce GTX 660 2GB Video Card $239.98
    Case Rosewill REDBONE ATX Mid Tower Case $34.99
    Power Supply Antec Basiq 500W ATX12V Power Supply $48.99
    Optical Drive Lite-On iHAS124-04 DVD/CD Writer $15.99
    (nothing much changed in this build i just threw in an upgraded PSU (450 to 500)
    so you can Overclock. and i changed the CPU to an i3 and the mobo to a B75.
    AMD:-
    CPU Intel Core i5-2300 2.8GHz Quad-Core Processor $179.99
    Motherboard ASRock H61M-DGS Micro ATX LGA1155 Motherboard $39.99
    Memory Pareema 8GB (2 x 4GB) DDR3-1333 Memory $31.89
    Storage Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive $54.99
    Video Card Sapphire Radeon HD 7950 3GB Video Card $304.99
    Power Supply Corsair Builder 430W 80 PLUS Certified ATX12V Power Supply
    PSin the AMD build you still need a case and an optical drive the total would be just above 670~)
    ALL OF THOSE are capable of running BF3 on high/ultra smoothly but the first build would lagg in ONLY AND ONLY 64 MAN MULTIPLAYER MATCHES that means it wouldn't lagg if the match had 32
    Well,Enjoy
New Build Systems
