I have had a air cooled computer now for a year and its pretty loud so i went out and bought 3 rads and a pump i have a xspc 360 rs radiator and a xspc 240 rs radiator and a single rad and was thinking it would be a waste to just cool my cpu with all them rads so im thinking about cooling my gtx 580 ( even tho it does not need cooling )
I have a ASUS DirectCU II GeForce GTX 580 the one with the big fans. Just wondering if anyone knows of any water blocks that will fit it ??? Because i have been told all 580s are different...
Also i have been told i will need pads for my block ???? Could some one explain ?
Also would it be worth water cooling my 580 ? Because at the moment im hitting 50c on full load and 30c on normal load...
