Approximate Purchase Date: This week
Budget Range: Not a set budget, just looking for a good deal
System Usage from Most to Least Important: No gaming, I run a large website online and do a lot of graphic work (photoshop, illustrator)
Are you buying a monitor: No, already have dual 23's
Parts to Upgrade: CPU, Mobo, Ram, Processor, PSU, CPU Cooler, Case, Ram
No need (Reusing) Harddrives, Graphics card, or DVD Drive
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg Or Amazon
Parts Preferences: Intel CPU
Overclocking: No
SLI or Crossfire: No, unless more practical for the price
Your Monitor Resolution: 1920 x 1080
Additional Comments: Looking for speed and ability to multi-task. I Realize my graphics card will be a bottleneck and will upgrade at a later date.
And Most Importantly, Why Are You Upgrading: Old motherboard died on me. Going to re-use Graphics Card, Harddrives, And Optical Drive
Parts I already have and I am re-using.
Nvidia 8800GTS 320GB pci e graphics card
Dual Layer DVD Drive SATA
64 GB Sata SSD OCZ Agility I believe - Will Be for OS
1 TB Sata Drive Will be for data
So
CPU - Like the I7, whats the difference between the 3770 and 3770k ? Just for over clocking ? If so lets go with the cheaper one
CPU Cooler - Would like a nice CPU cooler even if I am not over clocking. Don't have to go crazy on this
Motherboard - Very partial to ASUS boards. Lets stick with ASUS
Memory - I think 16GB will be what I am looking for in terms of performance.
Case - Pretty partial to this full size case here. Thoughts ? http://amzn.com/B007OX1R8K - Thermaltake Armor Revo
Power Supply - Planning for future where I will have a more beefy graphics card. Probably looking at around 700 W ? Modular would be nice but not required
Overclocking: No
So
