"There is no such thing as a dumb question. There are, however, dumb soldiers." SFC Thomas James, US Army, Nov. 15, 1975
New build. First build. OCZ ModXstream-Pro 600W power supply. Two LiteOn DVD/CD writers. Power supply has a Serial ATA cable with three (3) connectors. [See the cable by clicking the link to ModXStream Pro Mechanical Drawing on this page: http://www.ocztechnology.com/ocz-500w-700w-modxstream-pro-power-supply.html]. Can I connect both DVD/CD writers to the power supply using the one SATA power cable?
If no, thanks.
If yes, is there a downside to connecting both with the same cable instead of using one cable for each DVD/CD writer?
Thanks.
~George
If no, thanks.
Thanks.
~George
