Solved
Help on choosing a case
Hey I need help on these two cases
NZXT Guardian 921
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146070
Rosewill Challenger-u3
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147060
I just want to know if the NZXT is good and does it provide good cable management. And is there a bid enough difference in usb 3.0 and 2.0 in these cases to choose the Rosewill instead.
Thanks I can't choose between the two
9 answers Last reply Best Answer
More about help choosing case
  1. Best answer
    I have LOVED every single NZXT case I've used. And I'm currently lusting over the new Phantom.
    As for your other question... yes. USB 3.0 is worth it.
    However, your motherboard is going to have 3.0 ports on the back anyways.
    (Or won't have 3.0 headers, in which case it's a moot point.)
  2. cheaper yet great build quality from antec
    http://www.amazon.com/dp/B006TVQU6C/?tag=pcpapi-20
  3. What motherboard exactly did you get?
    The Challenger-U3 only has a front panel connector. If your mobo doesn't have an internal USB 3.0 header, there's no real point on it then.
  4. Check out the Fractal Designs Arc Midi for $70 at newegg. It have much better cable managementtan the Antec or Rosewill And has front usb 3 too.
  5. Seeing as the first choice is out of stock for now, you might want to change something up.
    +1. pick it up while its still on sale.
  7. the rosewill challenger won an award for being cheap , and as they pinned the medal on it they wished they could have afforded the Antec 300 in their $50 budget
    The antec 300 is now replaced by the 300 two
    and Antecs well build budget case is the Antec ONE . Its an excellent case for $55
    So is the HAF 912
  8. the antec one can be had for 44.99
  9. Best answer selected by N3wbu1lder.
New Build Rosewill Cases Systems Product
