G
Guest
Guest
Firstly, the RAM I'm using is 2x Corsair XMS3 2GB and the AsRock Z77 Extreme4. I was running the RAM in dual channel mode. So basically after 30mins maybe my screen would just freeze and I would have to restart. I initially thought I had damaged either of the sticks and I took one of them out. After that the computer would go at least 2 hours before any freezing. But because the freezing happened again, I went into the bios and I changed the speed down from 1333mhz to 1067mhz and low and behold the problem had disappeared. I'm now 48 hours without any problem.
But can anyone explain this?
