Hello,
I've been working on a new build and I'm looking for suggestions.
Approximate Purchase Date: in a few weeks
Budget Range: around $1000 after rebates
System Usage from Most to Least Important: gaming, storage
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg.com and amazon.com
Parts Preferences: Intel, AMD
Overclocking: A little on the CPU and GPU
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Additional Comments: When looking for parts I'd like the rating to be a least 4 out of 5 stars. I'm very unsure about a good motherboard and this is probably the area I need the most help on. I've selected two PSUs and am not sure if the more expensive one is worth it (puts me a bit over budget). Will I need different coolers for small amounts of overclocking on the CPU? Is the GPU a good match, performance wise, for the CPU I selected (don't want a bottleneck)
Parts List:
case: COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
optical drive: ASUS 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
ram: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
sata cable:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812119384
cpu: Intel Core i5-3570K Quad-Core Processor 3.4 GHz
http://www.amazon.com/Intel-Core-i5-3570K-Quad-Core-Processor/dp/B007SZ0E1K/ref=sr_1_1?
ie=UTF8&qid=1351650109&sr=8-1&keywords=i5-3570k
ssd: SAMSUNG 830 Series MZ-7PC128B/WW 2.5" 128GB SATA III
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147163
hdd: Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
gpu: SAPPHIRE 100352-2L Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
psu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131832
Thanks for any help you can provide!
Parts List:
sata cable:
psu:
motherboard:
