Tom's Hardware > Forum > Mobility Brands > Nokia > 8310 problem
8310 problem
Forum Mobility Brands : Nokia - 8310 problem
Archived from groups: alt.cellular.nokia (More info?)
Hi all,
Friend of mine has a N8310. Every now and then the display suddenly goes off
and text "insert sim card" appears. Switching it off and on again solves the
problem for a little while (most of the times). Really annoying though as no
calls can be received or made. No obvious reasons as water damage or other
accidents. I had the same years ago with my 8210.
axa
Sponsored Links
axauk wrote:
> Hi all,
> goes off and text "insert sim card" appears. Switching it off and
> on again solves the problem for a little while (most of the times).
> Really annoying though as no calls can be received or made. No
> obvious reasons as water damage or other accidents. I had the same
Could be dirty SIM contacts, try removing it and cleaning them thoroughly,
make sure the SIM is making good contact, I don't know the 8310 but some
phones use a clip to hold the SIM in place, check this is in good
condition.
Ivor
Reply to Anonymous
Hi,
> condition.
I had a very similar problem with a 5130, it turned to be an unbolted screw
inside (I heard it knocking when shaking the phone). Dismantled everything,
secured screw, no problem anymore.
Now it seems I have a problem with the tuner &/or antenna, but it doesn't
matter.
Regards,
G.T
g.t6@worldonline.fr
205 Diesel & turbo-Diesel : http://205d.fr.st
Reply to Anonymous
"axauk" <> wrote in message ...
> Hi all,
> off and text "insert sim card" appears. Switching it off and on again
> solves the problem for a little while (most of the times). Really annoying
> though as no calls can be received or made. No obvious reasons as water
> damage or other accidents. I had the same years ago with my 8210.
Take out the SIM card and cut and stick a post-it note on the back of it.
The extra width is enough to push the SIM card down onto the contacts that
little bit harder, ensuring a better contact with the SIM connections in the
phone.
Mike.
Reply to Anonymous
There are 523 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
