Help would be much appreciated. I am looking at building a custom pc with http://www.mwave.com.au/. I want it to run BF3 on high across 2 or maybe more monitors depending whether or not I can afford the monitors. All I know about it is that I want an AMD FX8350 CPU, an AMD Radeon HD 7970 3GB on a Asrock 990FX MOBO. Can you guys give me advice? What brand and speed RAM should I get? How much of it should I get? I was thinking 16GB but if so should I get 4x4GB RAM or 2x8GB RAM? Are all the components compatible? Do I need a sound card? What case and power supply? Also how big a HDD? I was thinking of maybe overclocking later on and maybe crossfiring if needed. If you could suggest a build on the website and post all the different components with the SKU numbers for http://www.mwave.com.au/. To get to the build a custom PC part of the website just click on Pc/Notebooks and build own pc. Sorry for such cluelessness but I really have no idea My budget is about 1500 with operating system. Help is highly appreciated!!
This is what I have put together.
• 17040389 X 1 – LG GH24NS90 24x Internal SATA DVD Burner Drive – OEM – Black (GH24NS90
• 28010742 X 1 – ASRock 990FX EXTREME4 Motherboard – AMD Socket AM3+ – AMD 990FX &
• 16011389 X 1 – Huntkey H001 Hercules ATX Midi Tower Chassis – SECC – 5.25" x4, 3
• 19040225 X 1 – AMD FX-8350 Black Edition 8-Core Processor – Socket AM3+ – 4.0GHz (Tur
• 34040861 X 1 – Cooler Master Silent Pro M2 Series 1000W Power Supply – Modular Cablin
• 22040472 X 1 – Western Digital WD Green 3.5" 1TB SATA 6.0Gb/s IntelliPower 64MB
• 37140953 X 1 – G.Skill Ripjaws-X 16GB(2x 8GB) Dual Channel Memory Kit – 240pin DIMM -
• 39090361 X 1 – Microsoft Windows 7 Home Premium – DVD – SP1 – 32-Bit – OEM (GFC-02021
• 42060906 X 1 – Sapphire Radeon HD 7970 Overclocked V2 Video Card – GDDR5 3GB 384-bit
I am not sure of everything though. Any recommendations on changing things and are they all compatible? Thanks.
