hbeduryan818 :
Well ill be buying from amazon and ill be more video editing but gaming wise people only saw a 4 or 5 fps lag with the 8350 compared to the 8150 which was lagging more than 10 and is crucial a better brand or samsung?
For gaming, the video card is all important.
For video editing, the cpu power and the number of cores is most important.
For 64 bit enabled apps like photoshop, the total amount of ram is important to reduce workfile I/O.
Do post links, preferably to newegg because it is easiest to check out the details and suggest better/cheaper components.
To my mind, Samsung and Intel are tops for reliability today.
For example, the most popular 256gb crucial M4 ssd($199) had 279 reviews, of which 14% had 0 or 1 egg reviews.
By comparison, the Samsung 830 256gb unit had 243 reviews, and only 4% were negative.
The Intel ssd numbers are comparable to samsung.
