Would really appreciate some advice here guys. I have done alot of reading, both here and around the net, but I'm still unsure as to what the problem is.
Here are my PC specs: (wasn't sure what parts to leave in/out)
Operating System: Windows 7 Home Premium 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120330-1504)
Language: English (Regional Setting: English)
System Manufacturer: MEDIONPC
System Model: MS-7366
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3072MB RAM
Page File: 1596MB used, 4544MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Card name: ATI Radeon HD 5800 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x689E)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_689E&SUBSYS_30701682&REV_00
Display Memory: 2295 MB
Dedicated Memory: 1015 MB
Shared Memory: 1279 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: HKC2160
Native Mode: 1280 x 1024(p) (75.025Hz)
Output Type: DVI
Driver Name: aticfx32.dll,aticfx32.dll,aticfx32.dll,atiumdag.dll,atidxx32.dll,atiumdva.cap
Driver File Version: 8.17.0010.1140 (English)
Driver Version: 8.982.0.0
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 7/28/2012 03:15:42, 931328 bytes
WHQL Logo'd: Yes
PSU: "BeQuiet Pure Power L7 530W"
The past few weeks, I've been experiencing a blurry/fuzzy screen display. This usually happens when the PC has been on for a while. My first thought was the monitor, as it is slightly damaged. So I have ordered a new one, but it's one week until delivery. However, after all the reading I've done - and temperature checking, I'm wondering if it isn't something else
I have tried taking a screenshot of the blurry screen, but it doesn't show up at all on the screeny, just appears normal. I did find a picture online which does look the same as my problem, only mine isn't as bad as this: http://i51.tinypic.com/b3pher.jpg Although I have to say, it does appear to be getting increasingly worse.
My graphics card when active (i.e. surfing/gaming) goes into the sixties. From what I have read, this is normal.
My CPU however goes ino the sixties also - and this isn't healthy is it? Here's a link to a screenshot from Speccy, but these are temperatures pretty much at idle (just browser open): http://oi50.tinypic.com/i3xawy.jpg
Yes, I have taken off the side panel from my PC - it's constantly off. I clean it out regularly with compressed air and I can see and hear the fans working properly. I did use MSI to manually increase the fan speed on my graphics card, as by default it was only at 25%. But I didn't notice that making any difference so reset it to default.
Any help/advice would be greatly appreciated! Thanks all.
Memory: 4096MB RAM
Monitor Id: HKC2160
Output Type: DVI
DDI Version: 11
WHQL Logo'd: Yes
