Archived from groups: alt.cellular.nokia (More info?)
Hi,
I just bought a nokia bluetooth headset (HDW-3).
I have hooked it to my laptop via a bluetooth dongle.
Unfortunately, I am not able to figure out how to make it work as a regular
headset so I can use to do Voice Over Ip (with skype for instance) or to
just listen for some regular music.
I already went in the the "audio" tab of the "sound and multimedia
properties" of my computer and selected the "Bluetooth audio" as my prefered
"sound play back" device. Unfortunately, it does seem to work. Only the
microphone seems to be recognized but not the playback capabilities (i.e.
the speaker of the bluetooth headset). Am I missinh something..?
Any help or pointer to a good website would be greatly appreciated,
I got it working. I had just forgotten to hold down the connect button of my
headset to activate the connection with my PC.
My headset is the Nokia HDW-3.
The only drawback is that the microphone sound is kind of weak even if i try
to max it out through the Windows "volume control" pannel.
FYI:
You may need to define the bluetooth headset as your main audio device.
For that matter, go in the config pannel---> "sound and multimedia" .
Select the "audio" tab of "sound and multimedia properties" choose the
"Bluetooth audio" as your prefered
"Francois G" <news_a1@cekoia.com> wrote in message
news:419c58f0$0$2343$8fcfb975@news.wanadoo.fr...
> Hi,
regular
prefered
> Thanks,
> Francois
