I setup a SonicWall VPN connection for myself from home into my work network. I have Verizon Fios, everything works fine. I have another remote user with Verizon DSL, same VPN settings. He can connect to the VPN but once connected, he not resolve hostnames and thus cannot browse the internet.
Based on threads here and elsewhere, here's what I've done:
1. Put the DNS server IPs in manually via the SonicWall VPN network connection properties.
2. Checked his Verizon gateway settings and confirmed that the VPN properties for PPTP PassThru, L2TP PassThru and IPSec PassThru are all enabled.
3. Disabled his local firewall.
4. ipconfig /flushdns, ipconfig /registerdns
5. Registry hack: HKLM\System\CurrentControlSet\Services\Tcpip\Linkage\Bind ... Took the last line "\Device\NdisWanIP" and put it at the top of the list.
6. Told him to call Verizon and ask for help
None of these have helped the issue. Any other suggestions? Please be basic with the instructions if you have any, this is my first VPN.
Thanks so much!
Thanks so much!
