Hello all,
I have just purchased a Asus GTX 550ti to replace my 9600 as it was getting a tad old.
I plugged it in all dandy and set it all up however I tryed to play Dayz and I got 20 fps on the lowest settings possible. I used to be able to play the game on around 20-30 fps on my old card. I though it was alittle weird plus most other games there are not huge improvements. I also looked and it did say something about the cpu bottlenecking the gpu ?
I noticed on Idle it runs at 55C andfull load around 65-70 which is high compared to my old card. I have a 120mm fan at the front bringing air in and one 120mm fan at the back pulling out with a small 80mm on the side pushing air out.
I also read that the graphics card uses alot of power in 12v Rails ?
I was wondering if you could tell me if this PSU I have will be able to cope with it.
http://www.dabs.com/products/best-value-alpine-700w-psu-120mm-red-fan-78ZS.html
My Specs are currently
Gigabyte 970-ud3A
4GB of Ram ( Got with the system)
Alpine 700W Red thingy Links - http://www.dabs.com/products/best-value-alpine-700w-psu-120mm-red-fan-78ZS.html
500gb Seagate Baracuda HDD
ASUS GTX 550 TI
Athlon X2 220 2.8ghz
Any help would be nice.
Gigabyte 970-ud3A
ASUS GTX 550 TI
