Hello all. I've built a pc for the first time in about 13 years. I've been using manufactured computers and laptops, and decided to build my own this time. First, my new baby is:
Gigabyte Radeon HD 7850
AMD FX-8120 3.1Ghz
ASUS M5A97 (OC version)
Sandisk Extreme 240Gb SSD
8Gb DDR3
Windows 7 64-bit
Inland 500w PS
Zalman Z11 Plus Chasis
So the problem I've having is the video drivers crashing and recovering. It happens fairly often, while I'm surfing the net (including trying to sign up for this site and typing up this post). I've tried (in no particular order)
* reformatting and using drivers on disc that came with the card
* reformatting and going straight to the v12.8 catalyst from AMD's site
* turning off the overclocking on the CPU
I've tried a couple of power supply calculator sites, and those vary greatly. Thermaltake said I only need 350W, ASUS (whom I'm a little more likely to trust) said I need at least 650W.
I'm unsure of what to do. At first, I was thinking maybe the card itself had a manufacturing defect. Now I'm wondering if it's because the power supply is too low. So I'm looking for your opinions. I'm happy to provide any other information, but you might need to tell me where to get it. The technology has changed a lot in 13 years. Thanks for any help.
Ben
AMD FX-8120 3.1Ghz
8Gb DDR3
Windows 7 64-bit
Inland 500w PS
Ben
