CPU - Intel G630
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116406
MOBO - ASRock H61M-DGS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157315
Memory - Kingston HyperX XMP Blu Red Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memo
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104339
GPU - PowerColor AX7750 1GBD5-DH Radeon HD 7750
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131461
PSU - Antec NEO ECO 520C 520W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
System Usage from Most to Least Important: Gaming
Parts Preferences: Intel CPU, ATI GPU
Your Monitor Resolution: the native resolution is 1920 x 1080, but its okay for me to go lower for the sake of fps.
I already have an optical drive, 1TB internal HDD, and a mini tower chassis. The nearest pc shop is http://pcx.com.ph/ so, i chose the above items depending on its availability on pcx store.
