Closed Solved
Do I have enough power for my HD6870?
Hey all,
I am upgrading my rig to be a bit more current with now-n-days.
I was told that my Logisys 600w was certain death and I should move on from my cheap way of digital life and get a new PSU. Well, I went a bit nutts and ended up getting a new mobo and graphics card along the way.
Soooo,
I now have.......
CORSAIR CX430 V2 - Builder Series 430W 80 Plus Certified
ASRock 970 Extreme3
AMD Phenom II X4 965 Black Edition 3.4GHz Socket AM3 125W Quad-Core Processor
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
XFX AMD Radeon HD 6870 1GB 256-bit Graphics Card Dual Fan
Now, I have the 430watt PSU and the Graphics Card is on the way, but I recently read on a few sites that this card requires a 500watt PSU.
Did I fail again! or are those requirments BS!
8 answers Last reply Best Answer
More about power hd6870
  1. Well, its better than your Logysis. Its pushing the power bill, but you should be fine as long as you dont overclock.
    Thanks for the info!
    So will I be unstable or at the edge with....
    Cooler Master V6
    500gb HD
    1 Optical Drive
    and mabey
    2X 120mm case fans and 1X HD fan??
    All that added on the above specs? Is it safe, because I have spent too much on PSUs lately. TY
  3. Best answer
    I think you should be fine as long as you don't overclock your processor.
    Sweet, Thanks MAn!~
  5. Personally, I think it's a bit tight.. I would not be comfortable with less than a 500W. Also, what happens if you want to add more RAM or HDD's later on?
    I do too, but seeing as its between that or his old Logysis...
  7. Best answer selected by JerryMcFail.
  8. This topic has been closed by Mousemonkey
Graphics Cards Graphics
