I have a possible DOA GPU or a, hopefully, compatibility issue that can be resolved.
My system is as follows:
Intel i5 3570K Ivy Bridge
ASUS P8Z77-V LK Z77 LGA 1155 R
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
OCZ ModXStream Pro 600W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity (100315L )
Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASUS 24X DVD Burner
COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
__________________________________
My GPU is not being identified by the OS. It is not displaying in Device Manager, at all.
I have tried the following trouble shooting in this order.
Reseat the card
Reconnect power
Download the latest driver
Uninstall and re-download the latest driver
Update the ASUS BIOS
Swear at my computer a lot
Before I call Newegg and ask for yet another RMA (I have had the shittiest luck. I have RMA'ed my PSU, MOBO, CPU, and now possibly my GPU), is it possible that there is just some sort of compatibility problem with my GPU?
The only thing that I have not tried is connecting a different GPU to ensure that my PCI port is working, and trying my GPU in another system. That will probably happen tonight or tomorrow.
Also the GPU is definitely receiving power at least; the fan spins.
I'm also building this with a very experienced builder, we should be able to troubleshoot most things.
Thanks,
Alex
ASUS 24X DVD Burner
Reseat the card
Reconnect power
Thanks,
Alex
