Hi Everybody,
So I put this together....
Optical drive: LITE-ON 24X DVD Writer Black SATA Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
Hard drive: Seagate Barracuda ST1000DM003 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
RAM: GeIL EVO Veloce Series 8GB (2 x 4GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144614
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
PSU: Rosewill CAPSTONE Series CAPSTONE-750-M 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182264
Motherboard: ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
Case: COOLER MASTER HAF X RC-942-KKN1Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
And it doesn't start. No fans no lights nothing.
I took the thing to a tech and spent $50 for him to tell me, without any specifics that it was the motherboard, and that I should RMA it. I noticed the power button there doesn't move up and down like the reset button. Maybe that has something to do with it...
Before getting the same model board back and I just want to be sure...
Are there any incompatibility issues notable in the parts I'm using? I've heard rumors of Ivy bridge incompatibility with the Asrock Extreme4 z77, regardless of what the specs say.
If I just decide to refund, instead of replace, the asrock which motherboard do you guys recommend? I don't think I like that company now.
