So I'm planning to upgrade/build my computer
Current: Acer Aspire X1800 (stock) + HD5570
Plan:
CPU - Intel i5-2500k - http://ark.intel.com/products/5220 [...] o-3_70-GHz
MOBO - Gigabyte GA-P67-DS3-B3 e5400 - http://www.gigabyte.com/products/p [...] id=3882#ov
RAM - Corsair Vengeance LP 8GB DDR3 1600Mhz Low Profile (2x4gb) - http://www.corsair.com/vengeance-l [...] 00c9b.html
GPU - Sapphire HD6850 1GB GDDR5 - http://www.sapphiretech.com/presen [...] =497&lid=1
PSU - Seasonic X-560watts 80 Plus Gold - http://www.seasonicusa.com/NEW_X-s [...] 60-850.htm
Cooler Master Hyper 212 Plus - http://www.coolermaster-usa.com/pr [...] ct_id=2923
Gonna be putting all of these in Cooler Master HAF912
But problem is, I cant buy all of these in one go. I'm planning to buy the mobo first so
1. Can I put all the components of my stock X1800 to that mobo?
2. Do all of the components that I want to buy compatible?
3. If I add another HD6850, will 560watts psu be enough?
I'm new in this, sorry. Also, I'm on a tight budget, but please if you can make my build more solid please help.
Plan:
