Solved
Using outside Power Supply for Desktop
Last response: in Systems
November 1, 2012 7:05:52 PM
Hi there. I just built a new PC. Nothing happens when I turn on the power switch, except maybe a try on the part of the CPU Cooler fan and the PS Fan. I figure that the Power Supply is not strong enough. It only delivers 15 A and 237W at 12V Aside from my system load, which is basic at this point, I'd like to know if I can hook up another power supply without actually installing it in the chassis, just to test. Any concerns about grounding? Thanks in advance.
More about : power supply desktop
Best solution
a b B Homebuilt system
a c 136 ) Power supply
November 2, 2012 1:57:51 AM
There shouldn't be any problem doing that - we do it all the time while "breadboarding".
November 11, 2012 11:13:14 PM
Best answer selected by bmarquardt2.
m
l
