Archived from groups: alt.games.battlefield1942 (More info?)
Hello,
If anyone can help with the problem below it would be very appreciated.
I just purchased and installed BF1942 WWII Anthology. It loaded fine
and runs perfectly for 5 minutes, then, everytime, it crashes to the
desktop after about 5 minutes. My machine is relatively new and meets
all the requirements. I'll paste system details below. Any advice or
comments are welcome.
Thanks,
john
SYSTEM AMD 2700+ chip
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Name AMD2500
System Manufacturer Ssystem manufacturer
System Model System product name
System Type X86-based PC
Processor x86 Family 6 Model 10 Stepping 0 AuthenticAMD ~1829 Mhz
BIOS Version/Date American Megatrends Inc. 1.00, 25/11/2003
SMBIOS Version 2.3
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale Canada
Hardware Abstraction Layer Version = "5.1.2600.2180
(xpsp_sp2_rtm.040803-2158)"
User Name AMD2500\John
Time Zone Eastern Daylight Time
Total Physical Memory 512.00 MB
Available Physical Memory 80.16 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 1.04 GB
Page File C:\pagefile.sys
VIDEO
Name NVIDIA GeForce4 MX Integrated GPU
PNP Device ID
PCI\VEN_10DE&DEV_01F0&SUBSYS_80C01043&REV_A3\4&2A33C5ED&0&00F0
Adapter Type GeForce4 MX Integrated GPU, NVIDIA compatible
Adapter Description NVIDIA GeForce4 MX Integrated GPU
Adapter RAM 128.00 MB (134,217,728 bytes)
Installed Drivers NV4_DISP.DLL
Driver Version 6.14.10.6693
INF File oem1.inf (nv4_Crush11 section)
Color Planes 1
Color Table Entries 4294967296
Resolution 1280 x 960 x 75 hertz
Bits/Pixel 32
Memory Address 0xFD000000-0xFDFFFFFF
Memory Address 0xE8000000-0xEFFFFFFF
Memory Address 0xF3D00000-0xF3D7FFFF
IRQ Channel IRQ 16
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\nv4_mini.sys (6.14.10.6693, 2.70
MB (2,826,944 bytes), 28/07/2003 2:19 PM)
SOUND
Name USB Audio Device
Manufacturer (Generic USB Audio)
Status OK
PNP Device ID USB\VID_047F&PID_0CA1&MI_00\6&2C037688&0&0000
Driver c:\windows\system32\drivers\usbaudio.sys (5.1.2600.2180
(xpsp_sp2_rtm.040803-2158), 57.88 KB (59,264 bytes), 02/01/2005 6:12 PM)
Name NVIDIA(R) nForce(TM) Audio
Manufacturer NVIDIA Corporation
Status OK
PNP Device ID NVAX\*NFORCE\4&121CA920&1&0000
Driver c:\windows\system32\drivers\nvapu.sys (5.10.2917.0 built by:
WinDDK, 236.00 KB (241,664 bytes), 21/01/2005 7:21 PM)
On Wed, 15 Jun 2005 21:48:41 -0400, John <jd_um_hoste@rogers.com>
in your profile's video.con you'll find a line something like this
renderer.allowallrefreshrates 0
change the zero to 1
otherwise you're stuck with 60hz
dr ratt
gary: so there's no chance we can be together?
lisa: only if you promise me you'll never die.
gary: you know i can't promise that.
lisa: if you could do that, i'd make love to you, right now.
gary: i promise. i will never die.
"John" <jd_um_hoste@rogers.com> wrote in message
news:h5SdncNui8D6Ry3fRVn-iQ@rogers.com...
> Hello,
> I just purchased and installed BF1942 WWII Anthology. It loaded fine and
> runs perfectly for 5 minutes, then, everytime, it crashes to the desktop
> after about 5 minutes. My machine is relatively new and meets all the
> requirements. I'll paste system details below. Any advice or comments are
> welcome.
> Thanks,
> john
> 8< snip
> dr ratt
Hi Dr. Ratt,
That parameter is already set to 1...
renderer.setFullScreen 1
renderer.fieldOfView 1
renderer.globalLodRadius 1
renderer.globalLodRadiusScaleFactor 5
console.showStats 0
renderer.allowAllRefreshRates 1
Thanks for the help though. Any other thoughts send them through :-)
John
>>Hello,
> Did you patch it to 1.61b?
Hi, th eversion in the start screen is
BF1942 v1.6
it does not show a "b" so I'll search for that patch. Thanks for the advice.
wrote:
>Hello,
>Thanks,
>john
>System Name AMD2500
>SMBIOS Version 2.3
>Locale Canada
>VIDEO
>PNP Device ID
>Color Planes 1
>Bits/Pixel 32
>IRQ Channel IRQ 16
>SOUND
>Status OK
>Status OK
Patch it and if you still have a problem check you cpu temp and/or
your motherboard board temp (a fix simply be a little thermal grease
in between the cpu and heatsink).
In article <dYudnaG79oYZxi7fRVn-tQ@rogers.com>, jd_um_hoste@rogers.com
says...
> >>Hello,
> BF1942 v1.6
> john
http://largedownloads.ea.com/pub/p [...] field_1942 _incremental_patch_v1.6_to_v1.61b.exe
Thank you to everyone, the patch solved the problem.
I should have thought of that.
John
> says...
>>>>Hello,
>>BF1942 v1.6
>>john
> http://largedownloads.ea.com/pub/p [...] field_1942 > _incremental_patch_v1.6_to_v1.61b.exe
> Here it is. 6.4mb
> Lansenerd
