Can a 405W power Supply run the ATI Radeon 5770?
Can my 405W power supply ruin the ATI Radeon 5770?
The recommended power supply is a 450W + for the 5770, but i've read loads of threads and i heard a good 400W power supply is fine, however i just need to make sure my 405W power supply will work with the 5770
I have a (405Watt, Make - CWT, Model - PUFP405P) power supply, i dont know if it's one of those very cheap ones, or a good one, but it was with a pc that i bought about 2 years ago for £700, so im not sure.
Thanks a lot.
Related ressources
so its dual rail. it says 17amps per rail. you dont just add them though.
405W/12 = 33Amps at best.
This should be fine for a 5770 to be honest but depends what else is in your system. amperage for cards are overegged (5770 draws 108 w so 108/12volts = about 10 amps.
However, it doesnt look like a great PSU as it has large amps on the 3.3/5 v rails, showing it is an older unit (newer PC components utilise 12v primarily).
I would maybe recommend a nice PSU upgrade and the gpu at the same time.
Graphics card Master
Power supply Authority
I hate when a power supply does not list the combined(for 12 volt rails).
As said above you can not just add them.
I would guess something in the 21-25 amp area to be honest.
If the rest of the system is lite(not a power hungry overclocked to the nuts cpu). A 5770 will run just fine.
This is a i5 750(under-volted for that extra power saving) + 5770 system with Just Cause 2 and Prime95 running :)
http://img841.imageshack.us/img841/3866/apcprimejustcause2.jpg
Do you know how i can find out the amount of watts im currently using, like you showed in the picture? I've looked everywhere, but i cant find it :??:
That is from my UPS unit( http://en.wikipedia.org/wiki/Uninterruptible_power_supp... ).
The cheaper way is to get a power meter/monitor( http://www.upm-marketing.com/products/em100.html )
You can find those at many hardware stores.
USA
http://www.homedepot.com/h_d1/N-5yc1v/R-202048563/h_d2/...
I am sure you can find on at other stores as well.
Canada
http://www.homedepot.ca/product/enpower-appliance-meter...
Canadian Tire has them as well under the Blue Planet name, but i did not see it on the website.
Ask the community
