Ok, so I have a strange problem. My computer after working flawlessly for 6 months had a total failure. It started one weekend when my rabbits got loose and chewed by computer cords. I replaced the cord and the computer would still not even power on at all. So I trouble shoot it took everything out and got it working fine out of the case, plugged it all back in and same thing powered up however it would not load windows at first so I restarted it said something about not being able to use last back up and gave me the option to delete it and start up I said ok started up looked fine. However every time after I start up applications about 2-5 mins in it starts to slow way down and its so bad my mouse jumps as it tracks over the screen. My cpu core 1 read out max's at 100% and never falls while the other cores sit a 1-5%. This happens when only running a single progams of which my computer could handle many all at once before.
Is this a software problem, or could I have do something while I was in there moving parts around. If anyone can help me? I'd be so happy.
Specs:
i5 3570k
azrock z77 extreme 4
gtx 670
raid max 850 gold cert.
Specs:
i5 3570k
gtx 670
