i'm a little confused about memory speeds and bus width. would 6GHz GDDR5 192bit memory interface width be the same speed as a 3GHz 384bit memory interface width?
the reason i'm asking is because i'm debating between getting a 660ti or a 670. i'm worried about the 192bit interface keeping the 660ti from releasing it's full power at 1080P. should i fork out the extra 100$?
(just so there is no confusion, i was just using random examples for my first question, not real specs of GPUs.)
