Massive 7750 problem!! Need help
So i bought an amd sappihire 7750 and installed it perfectly with drivers etc. and used it for a good 2 hours perfectly. Then i went to lunch shutting down the computer. When i tried to turn it back on nothing. I then though okay mybe mislodged card because no beeping. The computer turns on but no display is shown at all. Sounds like a PSU issue but not really srue could do with some helpzxxx
More about : massive 7750 problem
Related ressources
Like it never got past the bios screen ?
Sounds like the psu is dying slowly :cry:  Not sure though. Don't know how it works with the two 12v rails. ( one is 8A and the other 14A so i'm puzzled by that )
It ain't a really bad one though.
Ask the community
