First Build, kinda freaked out and could use some advise
Last response: in Systems
Hi Everyone!
I'm excited and frightened to attempt my first hands-on build. About 6 mos. ago, after almost a year of research I sourced out the components for a good, but basic media centre pc. I went to my local ncix intending to buy the parts and build it, but instead paid 50$ for them to build and warranty it. Since then I realized I want to play pc games on my media pc and have bought and installed a new video card(XFX 7870 DD) and an internal hd(1T WD black) as well as updated the bios for my motherboard. I know to many this won't sound like much but I was pretty fired up about it all and am now looking to build a full on gaming rig. Here's the info;
Approximate Purchase Date: Within the next 3 months or so. Willing to be patient for deals.
Budget Range: $1200- &1500
System Usage from Most to Least Important: Gaming
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: NCIX, Newegg
Parts Preference: Intel
Overclocking: Yes
SLI or Crossfire: Eventually
Your Monitor Resolution: 1920 x 1080
Additional Comments: Looking for a gaming rig that I can eventually crossfire. Need some advice regarding common mistakes to watch for.
Why Are You Upgrading:p artly so my gf can do homework on one while I use the other. Partly to build a computer.
Parts List
Mobo: Asrock z77 Extreme 4
http://www.ncix.ca/products/?sku=70902&vpn=Z77%20Extrem...
CPU: i5 3570k Planning to OC to around 4 - 4.2Ghz
http://www.ncix.ca/products/?sku=70541&vpn=BX80637I5357...
GPU: XFX 7870 Double D (Swapping out the video card on my current media pc and gonna run that with the onboard graphics from its i5 3470) But here's the link for informations sake.
http://www.ncix.ca/products/?sku=69829&vpn=FX787ACDFC&m...
SSD: 120g minimum, would love 256g. Samsung or Intel strike me as the best, but am open to advice.
HDD: Happy with the WD 1T Caviar Black I own, so I'd probably get another of those.
http://www.ncix.ca/products/?sku=50895&promoid=1016
RAM: I happen to have 8g(4x2) of Mushkin Enhanced Stilletto 1333 sitting around, but Im leaning towards getting 16g(8x2) 1600 for overclocking and to ensure compatibility. Here's the Mushkin link:
http://www.ncix.ca/products/?sku=55544&promoid=1360
Cooler: Maybe Coolermaster Hyper 212 Evo?
http://www.ncix.ca/products/?sku=64385&promoid=1016
PSU: I want quality here. Since I'm eventually going to be CFing two 7870's what would be a good wattage ceiling?
Optical Drive: Whatever.
Case: No idea. Atx with good airflow and 2 front usb 3.0 headers preferably.
Monitor: Also have no idea here. I like Samsung and Asus and would be looking to eventually buy another in order to CF.
So, I'm looking to find an SSD, a case, and a monitor for this set up but more importantly I want to know the little things. Like do I need thermal paste for when I attach the cooler? Do I buy that separately? When I first boot it will it automatically let me insert the windows cd? How often do CPU and Mobo joining go wrong? Should I be worried? Anyway, thanks everyone!
yay a canadian.
-buying a extreme4 in canada is a mistake. EXTREMELY overpriced
-just keep the mushkin ram that you already have
-overclocking ram is useless
-id get a blue drive. not much of a performance gain
-overclocking to 4.2ghz wont be much of a performance gain but ok
-the thermal paste proivded with the hyper 212 is good enough. id stick with it
heres what i would get
monitor: a pa238qr. have one myself. very good deal
http://www.ncix.ca/products/index.php?sku=69432&vpn=PA2...
case: my personal favourite. and its silent and has a near perfect layout
http://ncix.com/products/index.php?sku=75045&vpn=R4%2DB...
hard drive: just get a blue
http://ncix.com/products/index.php?sku=74462&vpn=WD10EZ...
motherboard. has everything you need to get going and overclocking
http://ncix.com/products/index.php?sku=70263&vpn=GA%2DZ...
psu: have one myself.
http://ncix.com/products/?sku=73229
optical drive: yeah. just get whatever is cheapest.
Thanks for the response, just going over everything you linked now. Ive never read that opinion on the Asrock board. I was originally looking for a gigabyte board, I currentlt have a H77 DS3H and its fine for what it does but my understanding was the Asrock was the way to go for gaming boards, plus its only 20$ more expensive. Let me read up a bit more on that gigabyte board though.
The fractal case seems pretty slick.
Mostly though, do I have a reason to be so worried about trying this? I am an electrician, so I am good with my hands and can follow directions well. Am I blowing it all out of proportion?
well, the asrock extreme4 is a great buy in the US, but that is only if it was 120-135 dollars. in canada, its 170 if you didnt notice
the gigabyte has the same features as the asrock + plus or minus a few
you should be good from now
Ask the community
