No red color on monitor, poor sound after move (Solved vga adapter)
MrAlba
24
thanks for reading
So I'm always on the road for work. I also like to play bf3, so I lug my pc around with me. I've never had a problem before but after the last move, no red color on monitor and sound output seems to only put out low bass end tones. I plugged the monitor and speakers into a laptop and they were fine. Does anyone have any suggestions before I tear down and rebuild everything?
Gigabyte ud4p mb, core i5 750, gtx 260, corsair 650 psu
MrAlba
24
I should have mentioned i pulled out the gpu and made sure it was in right. visual inspection and wiggled wires. I dont have access to another computer to test the gpu (good idea) but i could probably swing it by geek squad or something.
MrAlba
24
apparently the vga to dvi adapter was bad. it only worked on the laptop cause they were both dvi. I could not/cannot see anything visually wrong with the adapter, no bent pins etc. sound issue was unrelated (cheap speakers). thank you scout 03.
jamesj9493
This ended up being a problem with the VGA port on my PC... I recently installed a GPU for the "first time" and noticed it was not displaying red. It shows up fine through HDMI... It was a new GPU and the install did not go as smoothly as it could have, so I think it was something I did...
