Closed
Is my PSU enough to power a HD7870 or 7950?
Is it the X-Series 560W gold? If yes, it should have a 46A rating at the 12V rail. If that is the case, it is perfectly adequate of powering all of the cards you mention. One at a time ofc :p
Graphics card Master
Yes. That's the PSU I have, and it is running my HD7870 with an overclocked Phenom II without any trouble at all.
(not for long though; will be moving that card into my i5 rig as early as this weekend)
Related ressources
Best solution
nVidia itself recommend 500W for a single 670.You'll be fine
http://www.nvidia.in/object/geforce-gtx-670-in.html#pdp... Here is Guru3D's power supply recommendation:
Radeon HD 7950 - On your average system the card requires you to have a 500 Watt power supply unit.
Radeon HD 7950 Crossfire - On your average system the cards require you to have a 700 Watt power supply unit as minimum.
If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina.
System in IDLE = 165W
System Wattage with GPU in FULL Stress = 300W
Difference (GPU load) = 138W
Add average IDLE wattage ~3W
Subjective obtained GPU power consumption = ~ 138 Watts
Mind you that the system wattage is measured at the wall socket. Source: http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=w...
Ask the community
