Hey guys, as stated, this will be my first build and I need help picking between a few specs, to see what would fit me best. I would even accept suggested builds. I would like to stay as cheap as possible, i just want a decent computer to start with for 500-600 then i can upgrade later. My only desire is that it runs Grand Theft Auto 4 on Max Settings w/ ENB and hopefully gta5 when it comes out.
(as a side note, these builds are based on various barebones kits, and if they dont include HDDs, don't point it out, i already have a brand new one )
Build 1: This kit seems to include all necessary parts.
Kit w/ GPU: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5292602&Sku=B69-0612
Build 2:
Kit: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7380579&CatId=332
GPU: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=356682&Sku=E145-0554
Build 3:
Kit w/ GPU: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5551988&csid=_61
Build 4: (I Have no idea what GPU to put with this)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2826919&Sku=B69-0567
perhaps this GPU : http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=555358&csid=_61
Either Way, any help is greatly appreciated.
Also, if anyone can spare the time to explain this. Ive noticed that GPUs vary in Memory, both capacity (1gb, 1.5, 2...) and type (gddr5, etc). but its not as simple as just more ram the newer they are. Some may have 2gb memory yet are worse than one with 1gb, and a gtx560 can be worse than a gtx 550, I'm so lost. Graphics cards are the only part of a computer I do not understand. Please explain. Thanks alot for helping a new guy!
Build 2:
Build 3:
