I just bought my new Geforce GTX 560 SE, and placed it in the PC. I'm not sure if I need to use the 6 pin adapter thing it came with. I just found out that the card requires a 450w power supply and I only have a 300w. I don't know if that could be the problem or not, but on to my problem. After placing the card in the PC and hooking my monitor up to the card, and booting the PC nothing comes up but the fan on the card is running. So I hooked the monitor up to the normal vga port and decided to check to see if the card is being recognized in the device manager, it's not. Nothing at all is showing except Standard VGA graphics adapter, I have already disabled my integrated graphics card and I've tried to install the lastest drivers for it but it says can not find the graphic hardware.
HERE ARE MY SPECS:
I apologize for the length but I figured it was the best way to give proper info, so please help me out guys I really need it. If you need any other info let me know and I'll get it for you so you can help me. Thanks.
CPU-Z TXT Report
Binaries
CPU-Z version 1.61.3
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.924 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name AMD A8-3870
Codename Llano
Specification AMD A8-3870 APU with Radeon(tm) HD Graphics
Package Socket FM1 (905)
CPUID F.1.0
Extended CPUID 12.1
Brand ID 22
Core Stepping LN1-B0
Technology 32 nm
TDP Limit 117 Watts
Core Speed 2994.9 MHz
Multiplier x FSB 30.0 x 99.8 MHz
Stock frequency 3000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
L1 Data cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Min FID 8.0x
Min VID 0.450 V
# of P-States 8
P-State FID 0xE - VID 0x0B - IDD 20 (30.00x - 1.412 V)
P-State FID 0xB - VID 0x0E - IDD 18 (27.00x - 1.375 V)
P-State FID 0x8 - VID 0x12 - IDD 15 (24.00x - 1.325 V)
P-State FID 0x5 - VID 0x16 - IDD 13 (21.00x - 1.275 V)
P-State FID 0x3 - VID 0x1A - IDD 12 (19.00x - 1.225 V)
P-State FID 0x20E - VID 0x1F - IDD 9 (15.00x - 1.162 V)
P-State FID 0x208 - VID 0x24 - IDD 8 (12.00x - 1.100 V)
P-State FID 0x308 - VID 0x2A - IDD 6 (8.00x - 1.025 V)
Package Type 0x2
Model 71
String 1 0x5
String 2 0x1
Page 0x0
TDC Limit 80 Amps
Boosted P-States 0
Max non-turbo ratio 30.00x
Max turbo ratio 30.00x
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02040000h
Max CPUID level 00000006h
Max CPUID ext. level 8000001Bh
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 1 MB, 1 thread(s)
CPUID
0x00000000 0x00000006 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00300F10 0x00040800 0x00802009 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x00000006 0x00000000 0x00000000 0x00000001 0x00000000
0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00300F10 0x20002C71 0x000037FF 0xEFD3FBFF
0x80000002 0x20444D41 0x332D3841 0x20303738 0x20555041
0x80000003 0x68746977 0x64615220 0x286E6F65 0x20296D74
0x80000004 0x47204448 0x68706172 0x00736369 0x00000000
0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140
0x80000006 0x20800000 0x44004200 0x04008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x000001F9
0x80000008 0x00003028 0x00000000 0x00002003 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x0000040F
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000008
MSR 0xC0010061 0x00000000 0x00000070
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x800001C3 0x000016E0
MSR 0xC0010065 0x800001AF 0x00001CB0
MSR 0xC0010066 0x80000198 0x00002480
MSR 0xC0010067 0x80000184 0x00002C50
MSR 0xC0010068 0x80000176 0x00003430
MSR 0xC0010015 0x00000000 0x01000011
MSR 0xC001001F 0x04004000 0x00000200
MSR 0xC0010058 0x00000000 0xE0000021
MSR 0xC0010071 0x003F6007 0x400016E0
MSR 0xC0010070 0x00000000 0x00000000
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02040000h
CPUID
0x00000001 0x00300F10 0x01040800 0x00802009 0x178BFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 02040000h
CPUID
0x00000001 0x00300F10 0x02040800 0x00802009 0x178BFBFF
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 02040000h
CPUID
0x00000001 0x00300F10 0x03040800 0x00802009 0x178BFBFF
Chipset
Northbridge AMD K12 Bridge rev. 00
Southbridge AMD A55/A60M rev. 11
Graphic Interface PCI-Express
PCI-E Link Width x0
PCI-E Max Link Width x0
Memory Type DDR3
Memory Size 8192 MBytes
Memory Frequency 665.5 MHz (3:20)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Bank Cycle Time (tRC) 34
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 4096 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CMX4GX3M1A1333C9
Serial number 73691178
Manufacturing date Week 25/Year 10
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-23 @ 444 MHz
JEDEC #2 8.0-8-8-22-30 @ 592 MHz
JEDEC #3 9.0-9-9-24-34 @ 666 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Manufacturer (ID) (7F7F7F7F7F7F7F07)
Size 2048 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number HU524303EP0200
Manufacturing date Week 47/Year 11
Number of banks 8
EPP no
XMP no
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-25-34 @ 685 MHz
DIMM # 3
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP no
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 34 00
10 6C 78 6C 3C 6C 11 20 95 00 05 3C 3C 01 2C 83 81
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 02 9E 01 0A 1F 73 69 11 78 C4 C7
80 43 4D 58 34 47 58 33 4D 31 41 31 33 33 33 43 39
90 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
00 92 10 0B 02 03 19 00 01 03 52 01 08 0C 00 3C 00
10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 81
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 01 00 01
70 00 00 00 00 00 07 07 00 11 47 00 00 00 00 2E 24
80 48 55 35 32 34 33 30 33 45 50 30 32 30 30 00 00
90 00 00 00 00 02 FE 00 00 00 00 00 00 00 00 00 00
DIMM # 3
SPD registers
Monitoring
Mainboard Model Aspire M3470G (0x000003E6 - 0xC096F447)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8772
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8772
LPCIO Revision ID 0x0
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 72 00 00 00 04 0C 00 01 80 00 00 02 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 30 0A 20 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A30
Hardware Monitors
Hardware monitor ITE IT8772
Voltage 0 1.08 Volts [0x5A] (CPU VCORE)
Voltage 1 1.51 Volts [0x7E] (VIN1)
Voltage 2 2.90 Volts [0xF2] (+3.3V)
Voltage 3 4.76 Volts [0xEC] (+5V)
Voltage 4 11.38 Volts [0xED] (+12V)
Voltage 5 -8.93 Volts [0xBA] (-12V)
Voltage 6 -11.90 Volts [0xF8] (-5V)
Voltage 7 2.82 Volts [0x8C] (+5V VCCH)
Voltage 8 1.62 Volts [0x87] (VBAT)
Temperature 0 44°C (111°F) [0x2C] (TMPIN0)
Temperature 1 45°C (113°F) [0x2D] (TMPIN1)
Temperature 2 48°C (118°F) [0x30] (TMPIN2)
Fan 1 2220 RPM [0x130] (FANIN1)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 18 EE 07 00 00 00 00 00 80 48 C0 30 0E 2F FF
10 D6 CF 6D 66 C7 00 82 81 8F 01 FF 7C FF 8D 8D 8D
20 79 7E F2 EC EC BA F8 8C 87 2C 2D 30 80 C0 00 00
30 F3 27 FF E9 E7 FD DF FC FA 39 BE EF 67 EF B8 FA
40 16 DF D4 B7 FF 27 5F 40 AD 6A D4 00 FF FF FF FF
50 FF 18 7F 7F 7F 44 00 00 90 00 3C 12 60 00 00 00
60 01 41 55 42 30 04 0F FF 00 20 4B 55 96 02 0F FF
70 00 30 3C 7F D0 02 0F FF FF FF FF FF FF FF FF FF
80 FF FF FF FF 00 00 00 00 01 30 01 02 01 00 21 2B
90 42 50 C2 00 31 C8 42 00 52 99 00 00 01 40 B3 30
A0 A0 A0 A0 A0 A0 A0 A0 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1705
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 05 17 06 00 20 02 00 00 00 06 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 25 10 1D 06
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 02 20 00 00
50 25 10 1D 06 00 00 00 00 00 00 00 00 00 00 00 00
60 4E 00 00 00 06 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 10 00 00 03 00 00 00 00 31 20 00 00
90 00 00 00 C0 4B 01 00 00 00 01 20 00 00 00 00 00
A0 01 80 30 01 EF BE AD DE 00 00 00 00 00 00 00 00
E0 16 80 32 01 1F 00 FF 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 80 80 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x9640
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xC0000000
Address 1 (port) 0x0000F000
Address 2 (memory) 0xFEF00000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x50
Caps version 1.2
PCI capability
Caps class PCI Express
Caps offset 0x58
Device type Root Complex Integrated Endpoint Device
Port 0
Version 2.0
Link width 0x (max 0x)
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0xA0
Extended capabilities
Caps class Vendor Specific
Caps offset 0x100
Vendor ID 1
Size 16
PCI registers
00 02 10 40 96 07 04 10 00 00 00 00 03 10 00 80 00
10 08 00 00 C0 01 F0 00 00 00 00 F0 FE 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 0B 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 25 10 1D 06
50 01 58 03 06 00 00 00 00 10 A0 92 00 A0 8F 00 00
60 10 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
100 0B 00 01 00 01 00 01 01 00 00 00 00 00 00 00 00
110 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Multimedia device
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x1714
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEF44000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
PCI registers
00 02 10 14 17 06 00 10 00 00 00 03 04 10 00 80 00
10 00 40 F4 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00
60 10 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x170C
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Device type Root Port of PCI-E Root Complex
Port 4
Version 2.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps offset 0xA0
PCI capability
Caps class Subsystem Vendor
Caps offset 0xB0
SubVendor ID 0x1025
SubSystem ID 0x061D
PCI capability
Caps class HyperTransport
Caps offset 0xB8
Interface type MSI Mapping
Caps offset 0x100
Vendor ID 1
Size 16
PCI registers
00 22 10 0C 17 07 04 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 E1 E1 00 20
20 F0 FF 00 00 01 D0 01 D0 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00
60 00 21 00 00 12 0C 30 04 40 00 11 70 80 25 3C 00
70 00 00 48 01 08 00 01 00 00 00 00 00 1F 00 00 00
80 06 00 00 00 00 00 00 00 02 00 01 00 00 00 00 00
A0 05 B0 81 00 0C F0 E0 FE 00 00 00 00 B0 49 00 00
B0 0D B8 00 00 25 10 1D 06 08 00 03 A8 00 00 00 00
E0 50 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00
Description USB Controller
Location bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x7812
Revision ID 0x03
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEF4A000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x70
PCI capability
Caps class MSI-X
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 0
Version 2.0
Caps class 0x18
Caps offset 0x100
PCI registers
00 22 10 12 78 06 04 10 00 03 30 03 0C 10 00 80 00
10 04 A0 F4 FE 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 04 00 00 00 11 01 FF 00
50 01 70 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
60 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 05 90 86 00 00 00 00 00 00 00 00 00 00 00 00 00
90 11 A0 07 80 00 10 00 00 80 10 00 00 00 00 00 00
A0 10 00 92 00 C0 8F 00 00 00 20 10 00 00 00 00 00
C0 00 00 00 00 10 08 00 00 00 00 00 00 00 00 00 00
E0 FC 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 08 17 80 00 00 00 00 00 00 00 00 00 00 00 00 00
100 18 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x7812
Revision ID 0x03
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEF48000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x70
PCI capability
Caps class MSI-X
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 0
Version 2.0
PCI registers
00 22 10 12 78 06 04 10 00 03 30 03 0C 10 00 00 00
10 04 80 F4 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 00 02 00 00
100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description RAID Controller
Location bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x7802
Revision ID 0x40
PI 0x00
SubClass 0x04
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000F140
Address 1 (port) 0x0000F130
Address 2 (port) 0x0000F120
Address 3 (port) 0x0000F110
Address 4 (port) 0x0000F100
Address 5 (memory) 0xFEF51000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps class 0x12
Caps offset 0x70
PCI registers
00 22 10 02 78 07 00 30 02 40 00 04 01 00 00 00 00
10 41 F1 00 00 31 F1 00 00 21 F1 00 00 11 F1 00 00
20 01 F1 00 00 00 10 F5 FE 00 00 00 00 25 10 1D 06
30 00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00
40 10 00 C0 00 01 00 20 00 40 08 00 80 00 00 34 FC
50 05 70 86 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 50 22 00 00 00 00 00 00 00 00 00 00 00 00 00
70 12 00 10 00 0F 00 00 00 28 01 00 00 31 02 00 00
80 10 00 00 00 06 00 14 00 AB 01 08 00 F0 00 00 00
90 27 60 74 C7 7F 00 FF 00 01 41 17 00 20 01 00 00
A0 3D 58 11 00 0C 00 00 00 0D 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 10 00 00 FF 00 00 00 00
D0 13 00 06 03 00 00 64 00 00 00 00 00 00 00 00 00
E0 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 30 51 9A
Description USB Controller (OHCI)
Location bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x7807
Revision ID 0x11
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEF50000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x12
Int. Pin 0x01
PCI registers
00 22 10 07 78 06 00 A0 02 11 10 03 0C 10 00 80 00
10 00 00 F5 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00
40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00
50 40 13 18 F0 00 00 00 00 FF FF FF FF 00 00 00 00
70 00 00 00 00 FF 00 00 80 00 00 00 30 00 00 00 00
80 BB 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 18 (0x12), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x7808
Revision ID 0x11
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEF4F000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0xE4
PCI registers
00 22 10 08 78 06 00 B0 02 11 20 03 0C 10 00 00 00
10 00 F0 F4 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00
50 40 11 2A A0 7B AA 0F 00 00 00 00 00 00 00 00 00
60 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
C0 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x7807
Revision ID 0x11
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEF4E000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x12
Int. Pin 0x01
PCI registers
10 00 E0 F4 FE 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x7808
Revision ID 0x11
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEF4D000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps offset 0xE4
PCI registers
10 00 D0 F4 FE 00 00 00 00 00 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x780B
Revision ID 0x13
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 0B 78 03 04 20 02 13 00 05 0C 00 00 80 00
Location bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x780D
Revision ID 0x01
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEF40000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI registers
00 22 10 0D 78 06 00 10 04 01 00 03 04 10 00 00 00
10 04 00 F4 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 00 00 40 00 01 00 00 00 00 00 00 00 01 00 00 00
50 01 00 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x780E
Revision ID 0x11
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 0E 78 0F 00 20 02 11 00 01 06 00 00 80 00
40 04 00 00 00 D5 FF 03 FF 07 FF 20 00 00 00 00 00
60 00 00 00 00 00 0A 00 00 00 00 0F 00 00 FF FF FF
70 67 45 23 00 00 00 00 00 9C 00 00 00 00 0A 00 00
80 08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 01 10 D6 FE
A0 02 00 C1 FE 2F 01 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 E9 3D 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 80 E4 FF
D0 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
Vendor ID 0x1022
Model ID 0x780F
Revision ID 0x40
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 0F 78 07 04 A0 02 40 01 04 06 00 40 81 00
10 00 00 00 00 00 00 00 00 00 02 02 40 F0 00 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
40 26 00 3C FF 00 00 00 00 0C 0F 3F D1 00 00 00 00
50 01 00 00 00 08 00 03 A8 00 00 00 00 85 00 FF FF
60 CA 0E 17 00 BA 98 10 02 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06
E0 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 20 (0x14), function 5 (0x05)
Common header
Vendor ID 0x1022
Model ID 0x7809
Revision ID 0x11
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEF4C000
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x12
Int. Pin 0x03
PCI registers
00 22 10 09 78 06 00 A0 02 11 10 03 0C 10 00 00 00
10 00 C0 F4 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
50 40 03 18 F0 00 00 00 00 FF FF FF FF 00 00 00 00
70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1700
Revision ID 0x43
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 00 17 00 00 10 00 43 00 00 06 00 00 80 00
60 00 00 00 00 00 00 00 00 20 08 2E 00 10 06 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1701
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 17 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 3E 02 00 00 00 00 00 00 00 00
80 03 00 C0 00 00 00 FF 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00
C0 13 E0 00 00 00 F0 00 00 00 00 00 00 00 00 00 00
F0 01 40 00 C0 01 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1702
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 02 17 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 09 00 80 00 01 00 00 01 00 00 00 00
60 E0 3F 78 00 E0 3F 78 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 07 40 4A 05 90 04 22 18
80 77 00 00 00 51 00 A0 00 05 00 00 F0 54 B0 B2 01
90 00 00 60 06 8E 88 51 5E 0A E0 0F 8D 00 60 00 00
A0 00 00 00 00 01 00 00 00 00 00 40 00 00 00 00 00
B0 1C 21 BE 02 40 07 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00
F0 40 00 00 80 04 04 09 12 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1703
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Secure Device
Caps offset 0xF0
PCI registers
00 22 10 03 17 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 20 3B 03 02 40 00 30 0A 00 00 00 00 00 00 00 00
60 00 00 00 00 01 00 2A F2 00 00 00 70 1E 01 00 00
70 00 00 00 00 97 08 00 00 00 00 00 00 01 01 01 19
80 00 00 00 00 06 00 06 00 00 02 00 00 00 40 00 04
A0 D8 02 24 80 EF 0F C0 1E 00 00 00 00 00 00 00 00
D0 00 00 00 00 D4 4F 02 00 90 07 00 00 2A 07 6A 99
E0 00 00 00 00 20 0B 00 00 01 37 00 10 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 10 0F 30 00
Location bus 0 (0x00), device 24 (0x18), function 4 (0x04)
Common header
Vendor ID 0x1022
Model ID 0x1704
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 04 17 00 00 00 00 00 00 00 06 00 00 80 00
Location bus 0 (0x00), device 24 (0x18), function 5 (0x05)
Common header
Vendor ID 0x1022
Model ID 0x1718
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 18 17 00 00 00 00 00 00 00 06 00 00 80 00
Location bus 0 (0x00), device 24 (0x18), function 6 (0x06)
Common header
Vendor ID 0x1022
Model ID 0x1716
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 16 17 00 00 00 00 00 00 00 06 00 00 80 00
50 04 00 00 00 20 10 08 00 40 20 10 00 20 10 08 00
60 20 10 08 00 10 08 04 00 10 08 04 00 80 40 20 00
70 80 40 20 00 1E 00 00 00 37 00 00 00 09 88 52 0A
80 00 00 20 00 7F 3F 00 C6 00 00 00 00 00 00 00 00
90 1E 2C 00 80 09 00 00 02 00 00 00 00 F8 01 00 00
Location bus 0 (0x00), device 24 (0x18), function 7 (0x07)
Common header
Vendor ID 0x1022
Model ID 0x1719
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 19 17 00 00 00 00 00 00 00 06 00 00 80 00
Description Ethernet Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x06
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000E000
Address 2 (memory) 0xD0004000
Address 4 (memory) 0xD0000000
Subvendor ID 0x1025
Subsystem ID 0x8000
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Device type PCI-E Endpoint Device
Port 0
Version 2.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps class Virtual Product Data
Caps offset 0xD0
Caps class Advanced Error Reporting
Caps offset 0x100
Caps class Virtual Channel
Caps offset 0x140
Caps class Device Serial Number
Caps offset 0x160
PCI registers
00 EC 10 68 81 07 04 10 00 06 00 00 02 10 00 00 00
10 01 E0 00 00 00 00 00 00 0C 40 00 D0 00 00 00 00
20 0C 00 00 D0 00 00 00 00 00 00 00 00 25 10 00 80
30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
40 01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00
50 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 B0 02 02 C0 8C 00 00 07 50 19 00 11 7C 07 00
80 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 1F 00 00 00 10 00 00 00 00 00 00 00
B0 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00
D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 14 00 00 10 00 00 00 00 00 30 20 06 00
110 00 20 00 00 00 00 00 00 B4 00 00 00 01 00 00 05
120 03 00 00 00 00 00 08 01 00 00 00 00 00 00 00 00
DMI
BIOS Type American Megatrends
DMI BIOS
vendor American Megatrends Inc.
version P01-A3
date 11/21/2011
ROM size 2048 KB
DMI System Information
manufacturer Acer
product Aspire M3470G
version unknown
serial PTSJWP20012010515B9200
UUID {3F410FF8-C4F7-1220-0105-062250000000}
DMI Baseboard
vendor Acer
model Aspire M3470G
revision unknown
serial unknown
DMI System Enclosure
manufacturer Acer
chassis type Desktop
chassis serial unknown
DMI Extension Slot
designation PCIE#1
type B0
populated no
DMI Extension Slot
designation PCIE#2
type AC
populated no
DMI OEM Strings
string[0] AMD A75
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16384 MBytes
max# of devices 4
DMI Memory Device
designation DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM3
format DIMM
type unknown
data width 64 bits
DMI Memory Device
designation DIMM4
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 4096 MBytes
DMI Processor
manufacturer AMD
model AMD A8-3870 APU with Radeon(tm) HD Graphics
clock speed 3000.0 MHz
FSB speed 100.0 MHz
multiplier 30.0x
Graphics
Number of adapters 1
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name Standard VGA Graphics Adapter
Codename Sumo
Technology 32 nm
GPU ref clock 27000
PCI device bus 0 (0x0), device 1 (0x1), function 0 (0x0)
Vendor ID 0x1002 (0x1025)
Model ID 0x9640 (0x061D)
Performance Level 0
Software
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
ACPI
I deleted the acpi tree to reduce space!
HERE ARE MY SPECS:
CPU-Z TXT Report
Binaries
Processors
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Timers
Sys timer 1.000 KHz
Processor 1 ID = 0
Name AMD A8-3870
Codename Llano
CPUID F.1.0
Extended CPUID 12.1
Brand ID 22
Technology 32 nm
TDP Limit 117 Watts
FID/VID Control yes
Min FID 8.0x
Min VID 0.450 V
# of P-States 8
Package Type 0x2
Model 71
String 1 0x5
String 2 0x1
Page 0x0
TDC Limit 80 Amps
Boosted P-States 0
Thread dumps
CPU Thread 0
APIC ID 0
Type 02040000h
CPUID
CPU Thread 1
APIC ID 1
Type 02040000h
CPUID
CPU Thread 2
APIC ID 2
Type 02040000h
CPUID
CPU Thread 3
APIC ID 3
Type 02040000h
CPUID
Chipset
PCI-E Link Width x0
Memory Type DDR3
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP no
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP no
DIMM # 3
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP no
DIMM # 1
SPD registers
DIMM # 2
SPD registers
DIMM # 3
SPD registers
Monitoring
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8772
Config Mode LDN 0x4
Hardware Monitors
PCI Devices
Common header
Vendor ID 0x1022
Model ID 0x1705
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1002
Model ID 0x9640
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
PCI registers
Common header
Vendor ID 0x1002
Model ID 0x1714
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x170C
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 4
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0xA0
PCI capability
Caps offset 0xB0
SubVendor ID 0x1025
SubSystem ID 0x061D
PCI capability
Caps offset 0xB8
Caps offset 0x100
Vendor ID 1
Size 16
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x7812
Revision ID 0x03
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x70
PCI capability
Caps class MSI-X
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 0
Version 2.0
Caps class 0x18
Caps offset 0x100
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x7812
Revision ID 0x03
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x70
PCI capability
Caps class MSI-X
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 0
Version 2.0
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x7802
Revision ID 0x40
PI 0x00
SubClass 0x04
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps class 0x12
Caps offset 0x70
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x7807
Revision ID 0x11
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x12
Int. Pin 0x01
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x7808
Revision ID 0x11
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps offset 0xE4
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x7807
Revision ID 0x11
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x12
Int. Pin 0x01
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x7808
Revision ID 0x11
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps offset 0xE4
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x780B
Revision ID 0x13
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x780D
Revision ID 0x01
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x780E
Revision ID 0x11
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x780F
Revision ID 0x40
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x7809
Revision ID 0x11
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x061D
Int. Line 0x12
Int. Pin 0x03
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1700
Revision ID 0x43
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1701
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1702
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1703
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xF0
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1704
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1718
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1716
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x1022
Model ID 0x1719
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x06
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1025
Subsystem ID 0x8000
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Port 0
Version 2.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps offset 0xD0
Caps offset 0x100
Caps offset 0x140
Caps offset 0x160
PCI registers
DMI
DMI BIOS
version P01-A3
date 11/21/2011
ROM size 2048 KB
manufacturer Acer
version unknown
DMI Baseboard
vendor Acer
model Aspire M3470G
revision unknown
serial unknown
manufacturer Acer
DMI Extension Slot
designation PCIE#1
type B0
populated no
DMI Extension Slot
designation PCIE#2
type AC
populated no
DMI OEM Strings
string[0] AMD A75
usage System Memory
correction None
max# of devices 4
DMI Memory Device
designation DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM3
format DIMM
type unknown
data width 64 bits
DMI Memory Device
designation DIMM4
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 4096 MBytes
DMI Processor
manufacturer AMD
FSB speed 100.0 MHz
multiplier 30.0x
Graphics
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Codename Sumo
Technology 32 nm
GPU ref clock 27000
Performance Level 0
Software
ACPI
