Hi, just want to start out with saying this will be my first build I have ever done. With that being said let me get down to the details.
I currently do 3D design for games and naturally game quite a lot as well. So I have come here looking for you guys to give me a build that you would do if in my shoes.
My budget is ~$2000. If the parts sum equals 2k then I will add just a bit for Windows 7 pro 64 bit.
The types of programs I will be using are Zbrush, 3DS Max, Photoshop, and Marmoset tool bag. Probably all at the same time Or minus 3DS Max. These all can be pretty cpu intensive. So I need the build to have the power to do so and not stutter when I have millions of polygons on screen, a 4k texture in Photoshop, and listening to music on Youtube. Now that the work side has been mentioned, I do game quite a lot. I tend to stick to MMO's and competitive PvP. (player versus player) So I need to have the best reaction time I can get from the rig . Basically the best bang for the buck.
Looking at these things I'm guessing I need an i7 K, but what model I have no idea. I'm also thinking that running two 670's in SLI would be my best option for gaming.
Memory- Need to be able to have at least 32Gb. The build doesn't have to have it maxed out right away just the ability to upgrade to higher amounts. The more the better here.
On the side of cooling I have played with the idea of liquid cooling but it makes me a bit nervous considering if the cooler leaked I would be screwed.
I have never overclocked but knowing me If the cpu can do I will learn how to. The case can be any size but if the liquid cooling system runs up the price, then it needs to have the space for what it would take to overclock with air. As for looks as long as it stands out a bit I'm happy.
On a side note I don't need to purchase and peripherals I have those covered already.
So that pretty much sums it up. So what would you guys build if in my shoes for 2k?
