I have bought most of the system's components.
What do you recommend on how to install the system?
Here is what is in my mind.
- Install the case fans to the case.
- Install the power supply to the case.
- Install the CPU to the motherboard and avoid touching the pins of the motherboard or the CPU.
- Install the RAM DIMMs to the motherboard.
- Install the huge air coolers mounting kit to the motherboard
- Install the motherboard on the case.
- Install the huge air cooler and its fans to the motherboard in the case.
- Install the graphics cards.
- Install the HDDs.
- Install the SSDs.
- Install the DVD-RW.
- Connect the power supply cables (I do not know the recommended sequence)
- Connect the external peripherals (keyboard, mouse, headset .... etc)
- Bootup and wish that it runs successfully .
Also , I was wondering if i need to have the anti static mat and the anti static wrist wrap.
And If i can't get those , What actions can i do to avoid damaging my computer components?
Your help is appreciated
- Install the HDDs.
- Install the SSDs.
