Hello,
I need to replace my current video card with a new one and need recommendations.
I would like to get something quality for price not go much above $100
Does not matter if ATI or NVIDIA whichever is less problems/more reliable.
Current Card:
PowerColor AX5750 1GBD5-HV2 Radeon HD 5750 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card. http://www.newegg.com/Product/Product.aspx?Item=N82E16814131372 that is in my system currently. It has died.
I need a card that will work with both Windows 7 and Windows XP as I currently have XP and I am going to upgrade to 7 but I need to backup my files first and cannot see anything with a dead video card currently in the system.
I the card to support DVI, VGA, and Display Port
Needs Pixel Shader 2.0 support (this is what the game I play requires) http://www.paradoxplaza.com/games/europa-universalis-iii-divine-wind
Full requirements for the game:
System Requirements
Windows XP/Vista/7.0, Intel® Pentium® IV 2.4 GHz or AMD 3500+,
2GB RAM,
2 GB hard disk space,
NVIDIA® GeForce 8800 or ATI Radeon® X1900 video card,
Resolution at least: 1024*768
Direct X-compatible sound card,
DirectX®: DirectX 9
I am running a Gigabyte GA-P43T-ES3G motherboard.
Thanks in advance
Current Card:
System Requirements
2GB RAM,
DirectX®: DirectX 9
Thanks in advance
