Guys i need a step-by-step guide to connect cables
I have installed in the case : new mobo ,new ram memory,new cpu, but i need help connecting the cables.Because only these parts are new i need your help to connect the cables and want your opinion about buying more staff or not.
Here are my parts before upgrading :.
CPU : INTEL CELERON D 336
MOBO: FOXCONN P4M800P7MA
HDD: SAMSUNG SP1654N
PSU: HEC PRO 385
Also will my psu be compatible with the new mobo or not?
4 answers Last reply
More about guys step step guide connect cables
  1. I forgot to tell you which my new parts are
    CPU: i3 3220
    MOBO:gigabyte b75m-d3h
    ram:mushkin 2gb (don't remember details)
  2. That PSU should be ok as long as you are not using a dedicated GPU as it only has 18amp's on the +12 line. But from what I could see from google it looks like HEC makes quality components so it should be ok with a low cost rig.
  3. thanks but now how will i connect the cables?
  4. The cables are made to only fit into their designated slots.
New Build Connection CPUs Cable Systems
