Noise level of a gigabyte 680 vs my current card
I currently have a sapphire 6970 with an Arctic Cooling Accelero Xtreme Plus II Cooler and it's effectively silent (my 1000rpm noctua case fans are a lot louder).
What I would like to know is how loud is a Gigabyte GeForce GTX 680 2GB Overclocked?
http://www.gigabyte.us/products/product-page.aspx?pid=4178
Any help would be appreciated as I need to run a quiet computer and it's dificult to find good info regarding noise levels.
1 answer Last reply
More about noise level gigabyte current card
  1. Its one of the best cards non reference 680 you can get, as for being quiet..maybe a little louder than your Accelero. Under Idle its around 32 dba, under load much quieter than the 680 reference. You can also create a custom fan curve for more control over cooling and noise
Graphics Cards Cooling Gigabyte Graphics
