Solved
Ran into problem
Hello,
Today while I was building my new computer I ran into a problem. I have the mountain mods ascension case with 13 fans in it and my motherboard the asus rampage iv extreme only has 8 fan headers D: . So what should I do? Money is not a problem so any way will work.
Thank you,
Matt
13 answers Last reply Best Answer
More about problem
  1. I would suggest buying some fan splitters or controllers. Fan splitters would be cheaper and sometimes fan controllers can be unreliable..
  2. Best answer
    Are they all 3-4 pin fan connectors? Are any of the molex connectors? If some are molex, just hook them up to the molex connectors on your PSU.
    If none are, you may have to buy a 3 pin Y connector or a 3pin to molex connector.
  3. They came with a 4 pin to molex but my psu has no molex
  4. What fans do you guys recomend because if I buy something to solve the problem I might get some new fans
  5. Are you sure it has no molex? Can you send me a link to it?
    Well the only thing left is a Y connector.
  6. http://www.newegg.com/Product/Product.aspx?Item=N82E16817151109
    Will this be aple to run my 3 4GB GeForce gtx 680s stably.
  7. First off, why do you have 13 fans? -___________________________________-
  8. That is a VERY nice PSU. You chose well getting it. It should run your GTX 680's fine.
    Are you sure you you didn't lose the cable or anything? Because here It says it comes with 8 molex connectors.
    The mountain mods acension can hold 13 fans and would like to use them all.
    I will take a look in the bag again.
  11. Well guess what I found under my table the 4 pin to molex :D
  12. Best answer selected by ThatMoose.
  13. Thats great! Send me some pics of your system if you can, I want to see what all those fans look like in one case xD
New Build Systems Product
