Hey guys,
I had my HDD die the other day so I had to replace it and reinstall windows (suffice to say I now recognise the value of back ups and install discs). Since doing the replacement and such I've been having problems with my GPU. Basically if I try and connect to the monitor via the GPU (DVI, the blue cable, forget the name or both) window 7 gets to the splash screen with the glowing windows logo then the monitor cuts to no signal. If I connect through the onboard graphics windows boot properly and everything is fine. I've tried using both PCI slots for the actual GPU and both DVI ports for the cable and it's the same result every time. I was going to try it with my old GPU when I get home and see if I get any luck there. Tried clearing CMOS. Tried various combinations of RAM and HDD to no result. The GPU was working fine before the HDD failure so I wouldn't think it would be the card itself but you never know and the PSU is only like a week old. Anything you guys can suggest would be greatly appreciated.
Specs are:
ASRock extreme3 gen 3
i5 2500k (at stock)
GTX460SE
Corsair 550w PSU (forget the model name, sorry)
Kingston 1600Mhz RAM (4x 2Gb sticks)
Specs are:
i5 2500k (at stock)
GTX460SE
