First Build, need help making sure i chose the right parts
So i am building my first system, and I choose some components that I think are good, but I am not sure. Heres a list of what they are. I want to use this rig mainly for gaming, watching some movies, blender, and video editting. (Sorry for the long list)
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Item #: N82E16827135204
Return Policy: Standard Return Policy
Protect Your Investment (expand for options)
$16.99
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
Item #: N82E16811119225
-$20.00 Instant
$30.00 Mail-in Rebate Card
$199.99
$179.99
Western Digital WD Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822136769
Recover Your Data(expand for options)
-$10.00 Instant
$79.99
$69.99
ASUS VH236H Black 23" Full HD Widescreen LCD Monitor w/ Speakers
Item #: N82E16824236059
Return Policy: Monitor Standard Return Policy
-$30.00 Instant
$20.00 Mail-in Rebate Card
$199.99
$169.99
GIGABYTE GV-N660OC-2GD GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814125443
Return Policy: VGA Standard Return Policy
-$10.00 Instant
$239.99
$229.99
COOLER MASTER Silent Pro M2 RS620-SPM2E3-US 620W ATX12V V2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Full Modular ...
Item #: N82E16817171068
-$35.00 Instant
$119.99
$84.99
LITE-ON SK-1788/BS 2-Tone PS/2 Wired Standard Keyboard
Item #: N82E16823107120
$7.99
Logitech G400 Black 8 Buttons 1 x Wheel USB Wired Optical Gaming Mouse
Item #: N82E16826104577
-$15.00 Instant
$49.99
$34.99
Logitech Gift - League of Legends
Item #: N82E16800996803
-$15.00 Saving
$15.00
$0.00
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
Item #: N82E16820231460
Return Policy: Memory Standard Return Policy
$49.99
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Item #: N82E16832116986
Return Policy: Software Standard Return Policy
$99.99
AVG Anti-Virus 2012 - 1 User for System Builder - OEM
Item #: N82E16832620046
-$29.99 Saving
$29.99
$0.00
ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131821
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
Item #: N82E16819116504
Return Policy: CPU Replacement Only Return Policy
-$20.00 Instant
-$13.00 Combo
$479.98
$446.98
Subtotal: $1,391.88
EWRA: $8.00
Tax: $100.91
Shipping: $10.46
Grand Total: $1,511.25
IS there a way to lower the price by a little, or get a better bang for the buck. I want to stick with the Haf X, but if there is a better case for the money, I will choose which one. With rebates this lowers to about 1430.00, which I think is a acceptable price. One last thing, I am going to stick with Intel.
15 answers Last reply
More about first build making chose parts
  1. get the 7870
    I would take out the anti virus and get iobit app unistaller and malwarebytes. But I hate antivirus software, and I think of it as a virus in of itself.
  2. The antivirus is free as a promo.
    Also the gigabyte 7870 looks nice. Thanks!
    Anything else that i can change
  3. You might be able to switch to a cheaper asrcok or msi motherboard like this one
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130645
    and the i5 3570k, it would overall be cheaper, but you have to decide if those few extra features are worth it to you. The thing I said about antivirus is because, they bog down my pcs so much that I would just prefer to navigate the internet and check myself.
  4. I think ill stick with the mobo, because i think its one of the main things that i am going to spend more on. I decided to switch to the xfx double d 7870.
    +1
    The sabertooth's TFU armor is just a marketing gimmick. Imagine trying to remove that plastic armor when u'll need to change the BIOS battery. Not a pretty picture, eh?
    For your DDR3: go with: SAMSUNG 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model MV-3V4G3D/US ($38.99 @ Newegg)
    For your casing: Either Corsair Carbide 500R($109 promo @ newegg) or NZXT Phantom 410($99.99 @ Newegg) are a good choice since they will fit all graphic cards and an ATX motherboard.
    For your HDD: Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache Internal Desktop Hard Drive($100 promo @ Amazon) 5 yr warrranty, 1 TB Size hard disk and best quality you can get ;)
    For your PSU: CORSAIR Enthusiast Series TX650 V2 650W 80 PLUS BRONZE Certified Active PFC High Performance Power Supply ($64.99 after rebates w/ free shipping @ Newegg)An Absolute Steal!!!
    If you take into account my suggestions, you'll have enough savings to go with a radeon 7970 :D
  6. Im sticking with the mobo and case, but i did change the ram to cheaper 1600 modules
  7. GIGABYTE GA-Z77X-UP4 TH LGA 1155 Intel Z77 I found this, is it any good?
  8. Ok so i realized I can get the nxzt phantom for only 80 bucks! I think I might get that instead, is that a good idea?
  9. Yeah, I still think you should change the motherboard. It is true that the shield might just be a nuisance
  10. Ok, but which one do u reccomend?
  11. One last question, ive been looking at three cases, nxzt phantom 89.99, haf 932 139.99 and the haf x 149.99, i really like the haf x, and was wondering which case to get.
  12. I would go with the cheapest case.
  13. Kk thanks
  14. The asrock z77 formula, i can get 30 off
New Build Policy Systems Product
