I have HD 5670 1GB.....
I found its not giving display......I remove the monitor from graphics card and plug it to the onboard graphics....Still no display is there....then I remove the graphics card too and restarted my PC and display shows up....and every thing is fine but without graphics card....
nothing happened such thing before...i was playing heavy games very comfortably before.....
then I decide to disable what ever is related to PCI in BIOS and plug my card again on my mobo to see if i can start windows with the card plug in with monitor connected to onboard....
BUT NO LUCK THERE AS WELL and this annoys me very much because after disabling graphics card in BIOS it should give Display weather graphics card is in the slot or not...
please provide some guidance so that I could find out where the problem exactly is....
